Alarm “timeout” severity and SNMP forward
Solved2.87K views6th July 2023alarms SNMP Timeout Alarms
Bruno Sousa [DevOps Member]669 13th April 2023 0 Comments
Hello
Can you please tell how can we how can we differentiate the "timeout" severity from others (critical, major, minor, etc.) when we send "timeout" events from Dataminer to a 3rd party system via "SNMP forward" ?
Thank you.
Best regards
Bruno Sousa
Miguel Obregon [SLC] [DevOps Catalyst]23.68K Posted 14th April 2023 0 Comments
Hi Bruno,
A possible option is to configure a SNMP Manager with:
  • A different binding OID (a custom OID that you know represents a timeout alarm)
  • A filter that only accepts alarms with 'Timeout' severity
Below an example of the trap forwarded:
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 14th April 2023
