Alarm severity from view in automation script
Solved3.02K views12th January 2024alarm Automation view
André Kaiser [DevOps Advocate]532 4th July 2023 0 Comments
I have a question, that derives from this thread.
I would like to use the alarm state of a view (respective the highest severity of alarms in all views below that view) as variable in an automation script. Is there a method to retrieve that value from a view? This should then finally used to set a value of a property for this view.
My scripts looks like this and is working well with a fixed value instead of the alarm severity variable and includes some exception handling already.
public class Script
        ViewInfoEventMessage[] allViews = GetViews();
        if(allViews == null)
            engine.ExitFail("No views were found");
        foreach(ViewInfoEventMessage view in allViews)
            // do the filtering of views you want to update
            if(view.Name.Equals("ABC"))
                    UpdateViewProperty(view,"ABC","12345",engine);
    public void UpdateViewProperty(ViewInfoEventMessage view, string propertyName, string propertyValue, Engine engine)
        SetDataMinerInfoMessage request = new SetDataMinerInfoMessage();
        request.bInfo1 = Int32.MaxValue;
        request.bInfo2 = Int32.MaxValue;
        request.DataMinerID = -1;
        request.ElementID = -1;
        request.HostingDataMinerID = -1;
        request.IInfo1 = Int32.MaxValue;
        request.IInfo2 = Int32.MaxValue;
        SA sa = new SA();
        sa.Sa = new String[] { propertyName, "read-write", propertyValue };
        PSA psa = new PSA();
        psa.Psa = new SA[] { sa };
        request.Psa2 = psa;
        request.StrInfo1 = $"view:{view.ID}";
        request.What = 62;
        SetDataMinerInfoResponseMessage response = engine.SendSLNetSingleResponseMessage(request) as SetDataMinerInfoResponseMessage;
        if (response.iRet != 0)
            engine.GenerateInformation($"Update of property {propertyName} on View {view.Name} was not OK");
    public ViewInfoEventMessage[] GetViews()
        var getViewsList = new GetInfoMessage
    DataMinerID = -1,
    Type = InfoType.ViewInfo
DMSMessage[] dmsma = Engine.SLNet.SendMessage(getViewsList);
if (dmsma == null)
    return null;
        return Array.ConvertAll(dmsma, input => (ViewInfoEventMessage)input);
Could you enlighten me?
Many thanks in advance and best regards
André
André Kaiser [DevOps Advocate] Answered question 12th January 2024
Stacey Van Colen [SLC] [DevOps Member]2.74K Posted 5th July 2023 0 Comments
Hi André,
The following script should allow you to get the state of the view. You only need to provide the viewID, and then you'll get an information event with the State of the view.
namespace getviewstate_1
using System;
using System.Collections.Generic;
using System.Globalization;
using System.Text;
/// <summary>
/// Represents a DataMiner Automation script.
/// </summary>
public class Script
/// <summary>
/// The script entry point.
/// </summary>
/// <param name="engine">Link with SLAutomation process.</param>
int iView = 4;
Skyline.DataMiner.Net.Messages.GetViewStateMessage getview = new Skyline.DataMiner.Net.Messages.GetViewStateMessage();
getview.ViewID = iView;
getview.IncludeChildViews = false;
Skyline.DataMiner.Net.Messages.GetViewStateResponse mess = (Skyline.DataMiner.Net.Messages.GetViewStateResponse)Engine.SLNet.SendMessage(getview)[0];
  engine.GenerateInformation("View Level : " + mess.States[0].Level.ToString());
I took the liberty of putting this script already on the staging system with the name 'GetViewLevel'.
Hope this gives you the information you were looking for.
Kind regards,
You are viewing 1 out of 5 answers, click here to view all answers.
