Alarm severity from view in automation script
Solved3.62K views12th January 2024alarm Automation view
André Kaiser [DevOps Enabler]532 4th July 2023 0 Comments
I have a question, that derives from this thread.
I would like to use the alarm state of a view (respective the highest severity of alarms in all views below that view) as variable in an automation script. Is there a method to retrieve that value from a view? This should then finally used to set a value of a property for this view.
My scripts looks like this and is working well with a fixed value instead of the alarm severity variable and includes some exception handling already.
public class Script
        ViewInfoEventMessage[] allViews = GetViews();
        if(allViews == null)
            engine.ExitFail(“No views were found”);
        foreach(ViewInfoEventMessage view in allViews)
            // do the filtering of views you want to update
            if(view.Name.Equals(“ABC”))
                    UpdateViewProperty(view,”ABC”,“12345”,engine);
    public void UpdateViewProperty(ViewInfoEventMessage view, string propertyName, string propertyValue, Engine engine)
        SetDataMinerInfoMessage request = new SetDataMinerInfoMessage();
        request.bInfo1 = Int32.MaxValue;
        request.bInfo2 = Int32.MaxValue;
        request.DataMinerID = -1;
        request.ElementID = -1;
        request.HostingDataMinerID = -1;
        request.IInfo1 = Int32.MaxValue;
        request.IInfo2 = Int32.MaxValue;
        SA sa = new SA();
        sa.Sa = new String[] { propertyName, “read-write”, propertyValue };
        PSA psa = new PSA();
        psa.Psa = new SA[] { sa };
        request.Psa2 = psa;
        request.StrInfo1 = $”view:{view.ID}”;
        request.What = 62;
        SetDataMinerInfoResponseMessage response = engine.SendSLNetSingleResponseMessage(request) as SetDataMinerInfoResponseMessage;
        if (response.iRet != 0)
            engine.GenerateInformation($”Update of property {propertyName} on View {view.Name} was not OK”);
    public ViewInfoEventMessage[] GetViews()
        var getViewsList = new GetInfoMessage
    DataMinerID = -1,
    Type = InfoType.ViewInfo
DMSMessage[] dmsma = Engine.SLNet.SendMessage(getViewsList);
if (dmsma == null)
    return null;
        return Array.ConvertAll(dmsma, input => (ViewInfoEventMessage)input);
Could you enlighten me?
Many thanks in advance and best regards
André
André Kaiser [DevOps Enabler] Answered question 12th January 2024
Stacey Van Colen [SLC] [DevOps Member]2.75K Posted 5th July 2023 0 Comments
Hi André,
The following script should allow you to get the state of the view. You only need to provide the viewID, and then you’ll get an information event with the State of the view.
namespace getviewstate_1
using System;
using System.Collections.Generic;
using System.Globalization;
using System.Text;
/// <summary>
/// Represents a DataMiner Automation script.
/// </summary>
public class Script
/// <summary>
/// The script entry point.
/// </summary>
/// <param name=”engine”>Link with SLAutomation process.</param>
int iView = 4;
Skyline.DataMiner.Net.Messages.GetViewStateMessage getview = new Skyline.DataMiner.Net.Messages.GetViewStateMessage();
getview.ViewID = iView;
getview.IncludeChildViews = false;
Skyline.DataMiner.Net.Messages.GetViewStateResponse mess = (Skyline.DataMiner.Net.Messages.GetViewStateResponse)Engine.SLNet.SendMessage(getview)[0];
  engine.GenerateInformation(“View Level : ” + mess.States[0].Level.ToString());
I took the liberty of putting this script already on the staging system with the name ‘GetViewLevel’.
Hope this gives you the information you were looking for.
Kind regards,
Leander Druwel [SLC] [DevOps Member]2.10K Posted 5th July 2023 0 Comments
Hey Andre, any chance that you could further elaborate on the specific use case you’re trying to cover? As Stacey indicates, it is surely possible to get the alarm state from an automation script, but it might be good to understand the eventual purpose of it.
I notice that you’re also setting a property on the view according to the highest severity.
Just to see if there are other ways to achieve the end goal. 🙂
Thx
Leander Druwel [SLC] [DevOps Member] Answered question 5th July 2023
André Kaiser [DevOps Enabler]532 Posted 12th January 2024 0 Comments
I studied the script condition documentation on https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/Correlation_rule_syntax/Script_condition_functions.html
The script created via the help given above sets the a value for the property “BC_RP21 Alarm” on the view “RP21”. So to achieve what I asked in my last comment it might be good to use a script condition to compare, if the highest alarm, that enters the correlation rule (through a filter) is not equal to the actual property value. This would allow us to limit the execution of the script only when the highest alarm severity is above or below the actual severity of the view ( = property value).
Is it possible to compare to values to achieve the following condition:
“highest severity in filtered active alarms” not equal to “property value”
A script condition then might look like this:
max(field(severity)) != property(view.BC_RP21 Alarm)
… or must there be a integer/string value on the right side of the logic equation?
Many thanks and best regards
André Kaiser [DevOps Enabler]532 Posted 10th July 2023 1 Comment
Hello again,
looks like the script is doing, what it should do, but the trigger by a correlation rule is very sensitive and triggers the script N times depending on the number of active alarms in that view. I played a bit with various configurations of the correlation rule, but I did not find the right configuration to trigger the correlation only upon change of the alarm level of the view. I thought this might work via alarm grouping, but it doesn’t. My current configuration filters for alarm changes (New, escalated, dropped, masked, unmasked), which reduces the sensitive, but this does not resolve the root cause.
In an ideal scenario the correlation rule would only trigger the script when the severity of the view changes. In the recent configuration the correlation rule evaluates all active alarms in the view and triggers the script once per active alarm, that matches the filter / conditions. Thisworks, but is not pretty elegant and unnecessarily consumes processing resources.
André Kaiser [DevOps Enabler] Posted new comment 14th November 2023
André Kaiser [DevOps Enabler] commented 14th November 2023
Would there be someone who could imagine of a script condition, to filter out only changes on the highest severity in the view?
André Kaiser [DevOps Enabler]532 Posted 7th July 2023 0 Comments
Hello and many thanks!
I merged the GetViewLevel function into the script and got it working now. The property updates according to the current alarm level of the view. I just have to tweak my correlation rule to only be triggered on a change of the alarm level and not on any change on an alarm on the elements below.
The purpose behind is, that an external system. reads the properties of this view and shows a traffic light summary alarm in its UI. It uses the GetViewProperty method on the DM WebService already for other purposes and we want to avoid to implement another method in the driver just to get one single value from DataMiner. Otherwise there would be suitable WebService methods available out of the box.
André Kaiser [DevOps Enabler] Answered question 7th July 2023
