Alarm search problem.
Solved1.67K views18th October 2023
Melissa Alzate [SLC] [DevOps Member]176 11th May 2023 0 Comments
Could you please explain why the end-user is experiencing this?
On the DMA s-k5bem-p (ID 33410) we have the following elements.
End-user search by element name and find alarms of the past week for 3 of the 5 elements
Result (statistics view)
If I search by Dataminer agent instead
Result is only one element
However, if I search s-k2bem-p (DMA id 33409) as above I will find the timeouts from hael-1-A-dttvbt and klge-1-A-dttvbt
Why is that?
As you may notice by the element id’s, some elements has been migrated (long ago). The element id of hael-1-A-dttvbt and klge-3-A-dttvbt indicate that they were created on s-k2bem-p (33409)
hjs-1-A-dttvbt were created on s-k5bem-p (33413). Not sure if this has any relevance or just a coincidence.
The alarm id of all 3 elements all begin with 33413 which is correct.
--->I'm guessing that the way the filter works is that it is using the DMA ID and not the actual name ofthe DMA to find the elements.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th October 2023
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 17th October 2023 0 Comments
Hi Melissa,
Sorry for the late response, I lost track of this question.
I would suggest to create a ticket so we can investigate what is happening here as it looks like a bug to me.
