Alarm Grouping per System
Solved3.65K views11th July 2023Alarm Console alarm grouping alarm ID
Francisco Javier Pascual [DevOps Member]79 3rd May 2021 0 Comments
Hello!
we have three different systems in our DMS, each of them with a few equipments, categorized in a tree structure. When an alarm occurs on one equipment , there is no label to distinguish to which system it belongs to. Is it possible to do group or add a Group-ID to identify in the alarm console, to which system belongs the alarmed equipment?
Thanks
Simon Raine [SLC] [DevOps Member]2.08K Posted 3rd May 2021 2 Comments
Hi Francisco,
If I understand what you want to do correctly, I think this is a use case for custom element properties. You can add properties to all elements that belond to a certain 'system' in your DMS and make these available in the alarm console:
DataMiner Help
Francisco Javier Pascual [DevOps Member] Posted new comment 4th May 2021
Simon Raine [SLC] [DevOps Member] commented 3rd May 2021
That’s just one idea, another is if all your elements from each system are in specific views with a name relating to that system, you can just add the ‘views’ column to your alarm console.
Francisco Javier Pascual [DevOps Member] commented 4th May 2021
Thanks Simon! With the first answer was the problem already resolved. I have tested also your another suggestion and it is also good. Thanks a lot!
