Alarm console Comment Not Display “Comment added by … DATE/TIME”
Solved870 views23rd January 2025Alarm Console comment
Simon Nenez [DevOps Advocate]766 5th September 2024 0 Comments
Is someone know how to Display only the comment into the comment column of an alarm console ?
Bascially we have "Comment added by USER NAME @ DATE/TIME :" which is not interesting for us and hide the main info which is the comment
Thanks for you help.
Simon N.
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 6th September 2024 0 Comments
Hi Simon,
This is the standard way of showing a comment in the alarmconsole. Unfortunately it is currently not possible to trim the first part.
