Agent alias in system center
Solved2.06K views3rd October 2023
Carys Blackburn [DevOps Advocate]723 3rd October 2023 0 Comments
If the 'Name' field is changed in System Center > Agents > Manage, will this simply update the name/alias and not change any of the agent settings?
Thanks!
Carys Blackburn [DevOps Advocate] Selected answer as best 3rd October 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 3rd October 2023 1 Comment
Hi Carys,
I remember I saw a similar question in the past:
System Name change
This name is used to generate reports.
Hope it helps.
Carys Blackburn [DevOps Advocate] Posted new comment 3rd October 2023
Carys Blackburn [DevOps Advocate] commented 3rd October 2023
Thanks Miguel, it looks like this question is about changing company name rather than agent name though!
