Adhoc datasource wont load assembly
Solved1.16K views5th June 2025adhoc
Gerwin van der Kamp [DevOps Advocate]3.74K 5th February 2025 0 Comments
I created an adhoc datasource using an internal nuget.
When loading i get the following error:
Error trapped: Error thrown in implementation of GetNextPage: Could not load file or assembly ‘DataMiner.DOM, Version=1.1.24.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. An attempt was made to load a program with an incorrect format.
I found this question around this topic, so i moved the dll to the files directory but i still get this error.
It’s giving this error on at least versions 10.4.10.0-14882 & 10.4.5.0-14239
Any advice?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 5th June 2025
Gerwin van der Kamp [DevOps Advocate]3.74K Posted 5th June 2025 0 Comments
Figured it out:
The DLL needs to be in the /Files folder, not in an subfolder in /Files
Ronald Gerard [SLC] [DevOps Enabler]2.00K Posted 6th February 2025 12 Comments
Hi Gerwin,
This error usually occurs when trying to reference an assembly that is targeting a different CPU architecture (32 vs. 64 bit).
Can you check whether your internal Nuget is either targeting Any CPU, or x86/x64 depending on the OS where DataMiner (more specifically the SLHelper process) is running.
Gerwin van der Kamp [DevOps Advocate] Edited comment 29th April 2025
Gerwin van der Kamp [DevOps Advocate] commented 6th February 2025
Well the internal nuget is working with the normal automation engine.
But the target in the nuget is x86 <PlatformTarget>x86</PlatformTarget>
Ronald Gerard [SLC] [DevOps Enabler] commented 6th February 2025
Ok, then SLAutomation is probably running 32 bit while SLHelper is running 64 bit. Is it possible to change the PlatformTarget of the nuget to AnyCPU?
Then it should be compatible with both.
I'll give it an try.
Sara Gluhović [SLC] [DevOps Advocate] commented 12th March 2025
Hello,
I'm facing the same issue only with SLManagedAutomation, and it seems that method .AddRange() is the cause. I tried changing Build Target of the ad hoc data source project but that didn't help. Any ideas?
Gerwin van der Kamp [DevOps Advocate] commented 12th March 2025
To add to this, i recently upgraded to 10.5.3 but the issue still remains. to be fair i'm not sure if it is compiling the library anymore since i keep the same name altough i edit to include an number
Show 7 more comments
