Add Comment to an Alarm
Solved1.70K views18th January 2024
Aditiben Desai [DevOps Member]382 10th January 2024 0 Comments
Hello,
I am trying to add a comment to an active alarm using API call. The comment gets updated in the comment column but when I pull Alarm details after adding comment, the comments doesn't show up in alarm details.
Looking for possible solution to this.
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th January 2024
Aditiben Desai [DevOps Member]382 Posted 12th January 2024 2 Comments
I tried using Root Alarm ID for Get Alarm Details API call but the comment doesn't shows up. If I use the latest alarm ID which gets updated after adding a comment then using that alarm ID only the comment shows up.
Is there a way to get the new alarm ID after adding a comment ?
Aditiben Desai [DevOps Member] Posted new comment 15th January 2024
Wim Bruynooghe [SLC] [DevOps Advocate] commented 15th January 2024
Yes, that’s what I tried to explain with my previous answer:
1) After adding the comment, with GetAlarmHistory you can get the new alarm ID
2) With this new alarm ID call GetAlarmDetails
Aditiben Desai [DevOps Member] commented 15th January 2024
Is, there an automated way to get a new alarm ID after adding a comment ? Or manually we have to keep a track of new alarm ID which gets generated ?
