add an existing element into a view
Solved2.37K views6th June 2024direct view list view
peng fei212 2nd April 2024 0 Comments
Hi
I have an existing element already in a view and a service. And i created another new view. How could I link or add the existing element under the new view?
What i would like to achieve is one element under multiple views. Is that possible?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd April 2024 0 Comments
The alternative approach is also to right click in the Surveyor Console and active the "Drag-and-drop editing".  While active you can drag and drop elements to move them from one view to another.  If you hold the CTRL key while dragging and dropping, you will "copy" the element (i.e. the element will stay in the original view, but you will have it also in the new view where you dropped it).
This is a more efficient way if you want to do multiple of those actions to reorganize and rearrange your elements.
