add an existing element into a view
Solved2.37K views6th June 2024direct view list view
peng fei212 2nd April 2024 0 Comments
Hi
I have an existing element already in a view and a service. And i created another new view. How could I link or add the existing element under the new view?
What i would like to achieve is one element under multiple views. Is that possible?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 3rd April 2024 1 Comment
This is possible, you can do this by going to the edit menu of the element and checking multiple views under the 'views' tab.
Michiel Saelen [SLC] [DevOps Advocate] Posted new comment 3rd April 2024
Michiel Saelen [SLC] [DevOps Advocate] commented 3rd April 2024
Learning video: https://community.dataminer.services/courses/dataminer-administrator/lessons/elements/
Time in the video 33:20
