Abort automation script
Solved2.62K views8th March 2024Automation script
Ana Pinho [SLC] [DevOps Member]1.42K 7th March 2024 0 Comments
I want to abort an automation script using:
ScriptControlMessage abortMessage = new ScriptControlMessage(DataMinerID)
ScriptID = scriptID, //this is the running automation script ID
Type = ScriptControlType.Detach // this aborts the script
How can I get the script ID when I only know the name?
IDmsAutomationScript only has Name, Description..
Thank you,
Ana
Ana Pinho [SLC] [DevOps Member] Selected answer as best 8th March 2024
Robin Spruytte [SLC] [DevOps Advocate]798 Posted 7th March 2024 3 Comments
Hi Ana,
I could not find a way to request the active script IDs as seen in the screenshot from João's response. The ID is however returned as part of the ExecuteScriptMessage response, so that would be my only guess to be able to actually get a hold of these IDs if you decide to execute all scripts via this call.
Thomas Ghysbrecht [SLC] [DevOps Enabler] Posted new comment 8th March 2024
Ana Pinho [SLC] [DevOps Member] commented 7th March 2024
Hi Robin,
Thank you for the suggestion!
I tried it out on the client test tool with several automation scripts and I get always ScriptID 0.
Robin Spruytte [SLC] [DevOps Advocate] commented 7th March 2024
Hi Ana, I was using the ‘Follow’ option while executing scripts and then aborting them. I could see that ExecuteScriptMessage response had a ScriptId, and the abort message was using that same ID. I was executing from the Automation Module ‘Execute’ button. I’m not sure why that gives different results than doing it from Client Test tool. You could check if there are other properties missing in the ExecuteScriptMessage.
Thomas Ghysbrecht [SLC] [DevOps Enabler] commented 8th March 2024
The script ID will only be returned when an interactive script is executed. (ExecuteScriptMessage contains ‘INTERACTIVE’ option)
