A way to position nodes consistently across multiple Node-Edge diagrams
Solved1.98K views7th July 2023Node edge graph
Bing Herng Chong [SLC] [DevOps Advocate]1.73K 13th March 2023 0 Comments
Hi, I have a number of Node-Edge diagrams and each of them may contain the same nodes. See attached diagrams for examples.
The text on the diagrams are a little small to read but essentially each node represents a location. Below is a list of location for each Node-Edge diagram.
Core:(ASEQ|AVN|CGL|ERN|HNP|KKU|LNH|OTB|PNP|SKT|SLF|TEA|TGP|TVC|WTA|WTE|EGT|GDS|MHI|SDM|BLM|RVC|TTBM|TTNN|TTTG|TTWN|TTTU|TTGM|TTIN|TTDN|TQST|DUR|TTCH|TTAR|NAT|TTLE|ASGX|TTFH)
Auckland:
(CWFS|ASEQ|NDC|SKT|TVC|WTA|PAN|AKO|PHL|UDC|TCDC|TMDR|VCDC|ICDC|DTDC|AKDC|AKV|PADC|MTET|STDC|ASGX|RVA|TTFH)
Upper North:
(HNP|HNT|KPU|PPO|ROT|SKT|TEA|TTU|TVC|WTA|WHP|HIK|HKA|HNA|KPA|MTA|PAE|TMA|TMDR|TTHT|TTRO|TTTG|NPWH|TTTP|DHDC|TTWK|SWRI|TFWF|TTFH)
I want to be able to give a particular node a fixed coordinate if it appears on that Node-Edge diagram. For example: SKT appears in all 3 and I want it to be placed in the same point. Is there a way to do this? (e.g.: manual configuration of the .json file)?
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 13th March 2023 0 Comments
Hi Bing,
Manually positioned nodes are saved per node-edge component in the dashboard. There currently is no way to have dynamic positioning based on columns of a GQI result. Changing the JSON file is not recommended as the internal structure of a dashboard is not backwards compatible.
Feel free to create a new feature suggestion for this.
