DataMiner SRM installation package
Before you install DataMiner SRM, make sure your system meets the requirements listed in the getting started guide.
Select the package below to go to the downloads page for the latest version of DataMiner SRM. You can use the installation package to install SRM from scratch or to update an existing SRM installation.
Three different release tracks are available:
  • Main release version: To be used with the main release track of DataMiner.
  • Feature release version: To be used with the feature release track of DataMiner.
  • Feature release (Dev Pack) version: To be used with the feature release track of DataMiner and the SRM Dev Pack. For more information, see SRM scripting using the SRM Dev Pack.
For more information on DataMiner SRM, refer to the DataMiner User Guide.
