DataMiner 10.7 is just around the corner. Alongside many big, exciting new features, it also retires several outdated ones, including the use of the legacy languages JScript and VBScript in Quick Actions (QActions). Because this change can block your upgrade, it’s worth checking your system before you upgrade.
DataMiner connectors have historically allowed QActions to be written in JScript or VBScript as well as C#. As of DataMiner 10.7, those two legacy options reach End of Life, and C# is the replacement.
Unlike some other retired features, there is no soft-launch option to keep using JScript or VBScript QActions after the upgrade. Any connector that still relies on them needs to be updated or removed first.
You may be affected without knowing it
Your connectors may already use C#, but older versions of those connectors, with JScript or VBScript QActions, can still be on your system long after you stopped using them. Old versions often stay behind after a connector update, especially on systems that have been running for a long time.
What happens when you upgrade
When you upgrade to DataMiner 10.7.x, a prerequisite check looks for connector versions that still use JScript or VBScript QActions. If it finds any, the upgrade won’t start, so you can deal with those connectors first and your elements don’t stop working unexpectedly.
If you upload a connector that uses these languages after the upgrade and then create an element with it, that element goes into an error state and won’t run.
What should you do?
- Check whether your system is affected:
As soon as it’s available, upload the DataMiner 10.7 upgrade package using the Upload only option. This runs the prerequisite checks without upgrading your system, so you’ll see whether any connector versions still use JScript or VBScript QActions. We recommend doing this a few days before your planned upgrade, so you have time to fix any issues. - Clean up connectors from the Catalog:
Install the latest version of the affected connector*, make sure your elements use it, and delete the old versions in the Protocols & Templates module. The elements tab of that module shows which elements use which connector version.
*No newer version available? Contact Skyline support and we’ll publish an updated version in the Catalog. - Update your own connectors:
If you developed a connector yourself, rewrite its JScript or VBScript QActions in C#. You can recognize them by the encoding attribute of the QAction in the connector XML.
For example:<QAction id="100" name="Name" encoding="jscript" triggers="500"> ... </QAction>
