integration Use Case
Field power supply manager for cable companies
SCTE
This DataMiner solution manages thousands of field power supplies across a vast territory allowing remote testing, advanced diagnostics, and fault forecasting. As a result, significant savings have been achieved in terms of truck rolling, ensuring timely deployment of the appropriate teams, and fostering improved communication among crews, thus enhancing operational efficiency.
The solution supports bi-directional communication between DataMiner and HMS Power Supplies with both IPv4 and IPv6. It also facilitates monitoring, remote testing, capacity planning, and proactive external network maintenance.
