Working Automation Script Error
Solved1.99K views4th April 2025#automationscript
edward.smith@fox.com Smith200 11th February 2025 3 Comments
This is a follow up question that is related to a previous solved question.
For context, I have the script working on a Lab DMA with no errors. I exported the script and then imported it on another system, and it works beautifully with the exception of throwing this error. When you click "OK" after the confirmation dialog, it makes the changes very quickly, then pauses for a few seconds and generates this error.
It behaves the same whether I launch it directly from the automation area, a Visio in Cube, or from the Visio on the monitoring web interface.
edward.smith@fox.com Smith Selected answer as best 4th April 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 11th February 2025
Hi Edward,
Have you tried disabling the option 'After executing a SET command'
https://docs.dataminer.services/user-guide/Advanced_Modules/Automation_module/Running_Automation_scripts/Script_execution_options.html
edward.smith@fox.com Smith commented 11th February 2025
This is what I have on the button: Script:webclick||dmaID=19**51;elementID=6;parameterNumber=155;tableIndex=f4b749d8-5794-4b19-bce8-81fe1af17134;parameterValue=2|||NoConfirmation,CloseWhenFinished
Are you suggesting adding an additional instruction after CloseWhenFinished?
Hi Edward,
Yes, can you try adding 'NoSetCheck'?
More information here:
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_an_Automation_script.html#options
edward.smith@fox.com Smith200 Posted 13th February 2025 0 Comments
I added the NoSetCheck and the script did not error on Cube but then it did with the web.  This was the error on the web.
edward.smith@fox.com Smith Answered question 13th February 2025
