Will the Automation script C# code reference be extended for DataMiner apps?
Solved3.22K views14th October 2020Automation jobs ticketing
Kevin Vermeulen [SLC] [DevOps Member]552 1st October 2020 0 Comments
Currently, you can do various things with the C# code reference. Getting an parameter from an element etc.
What I'm missing for the apps that are available, Ticketing, Jobs etc. to also have methods provided(Create Job, Edit Job, Delete Job, Create JobDomain), (Create Ticket, Create TicketDomain) etc..
Internally we have solutions for this, but perhaps such methods as above could general be available for customers and supported through the official DataMiner help.
Kevin Vermeulen [SLC] [DevOps Member] Selected answer as best 14th October 2020
Desmet Thomas [SLC]20 Posted 1st October 2020 0 Comments
This is possible in automation script using the api-helper methods. As you need to setup the helper its not always possible to create standalone methods to create ticket etc.
There is also a very good client-side UI available to manage jobs and tickets which should be the recommended way to use.
