Will DataMiner items from a previous SRM solution be overwritten when installing a new solution
Solved2.03K views14th October 2020SRM
Kevin Vermeulen [SLC] [DevOps Member]552 13th October 2020 0 Comments
When you have a DataMiner with SRM-automation scripts from a previous solution, will these be overwritten when installing a new SRM solution? Probably yes?
Is this also the case for Visio's and protocols?
Kevin Vermeulen [SLC] [DevOps Member] Selected answer as best 14th October 2020
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 13th October 2020 0 Comments
Yes, by installing a new SRM package, some automation scripts, dll files, visios, protocols might be overwritten.
However custom automation scripts, not part of the SRM standard solution still remain untouched. (like LSO scripts, like profile load scripts)
