Why the does the protocol in production does not read “signed by Skyline Communications?
Solved1.76K views21st September 2020
6
João Pereira [SLC]130 21st September 2020 0 Comments
Installing a new protocol on DataMiner correctly shows "Signed by Skyline Communications" and "Provided by Skyline Communications":
However, when the protocol is set as production, it shows "Signed by a third party":
In order to have consistency and avoid misunderstandings, is there a way to correct this behaviour?
Thank you for your help.
João Pereira [SLC] Selected answer as best 21st September 2020
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 21st September 2020 1 Comment
Hi João, This is a software issue. See task 83879 for more information.
Marieke Goethals [SLC] [DevOps Catalyst] Edited answer 21st September 2020
João Pereira [SLC] commented 21st September 2020
Thank you for your answer Matthias, cheers!
