Why is the engine element’s GetParameter method throwing an exception?
Solved1.27K views8th December 2022automation engine
Brecht Deconinck [SLC] [DevOps Member]1.32K 8th December 2022 0 Comments
Why is the GetParameter method to receive the value of a cell via the name and idx not working?
An exception is thrown that the object could not be found.
(Script Automation script/2) Get Parameter 778/7283/-1/ failed (The object or file was not found.: 0x80040239)
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.Element.GetParameter.html#Skyline_DataMiner_Automation_Element_GetParameter_System_String_System_String_
Brecht Deconinck [SLC] [DevOps Member] Selected answer as best 8th December 2022
Robbie Demaegdt [SLC] [DevOps Member]666 Posted 8th December 2022 2 Comments
The GetParameter method uses the description of a parameter, not the name.
Ben Vandenberghe [SLC] [DevOps Advocate] Posted new comment 8th December 2022
Brecht Deconinck [SLC] [DevOps Member] commented 8th December 2022
Would it be possible to have the documentation updated to avoid confusion?
Ben Vandenberghe [SLC] [DevOps Advocate] commented 8th December 2022
Hi Brecht – can you use the Propose Change on the top right of that page to make that suggestion? That flows automatically to the technical writer squad.
