Why do we need to use the $ prefix when defining default alarm thresholds for exception values?
Solved1.28K views5th November 2024alarm monitoring Connector driver development exception threshold
Michiel Clepkens [SLC] [DevOps Advocate]1.43K 25th October 2024 0 Comments
Hi Dojo
The DataMiner Development Guide explains that we should use the $ prefix when defining default alarm values for exception values in a protocol: Alarming | DataMiner Docs. I'm wondering why we need that prefix. Would anyone know the technical background?
Thank you in advance!
Kind regards
Michiel Clepkens [SLC] [DevOps Advocate] Selected answer as best 5th November 2024
Davy Degrande [SLC] [DevOps Advocate]1.76K Posted 28th October 2024 1 Comment
This is because it uses the same syntax as the alarm template configuration.
There you just pass on a value to monitor on. The dollar sign tells SLElement that this is an exception value and is treated slightly different than normal values.
Michiel Clepkens [SLC] [DevOps Advocate] commented 5th November 2024
Thank you for your answer Davy. It’s clear now. Much appreciated!
