Why can’t display Source ID, Destination ID and other to table from MENU QUERIES for DCF connection.
Solved1.93K views31st May 2024
Jaroslaw Burtny [DevOps Member]756 17th January 2024 0 Comments
Hi All.
I don't get parameters like Source ID, Destination ID and other …. to table from MENU QUERIES for DCF connection.
Where does Dasbord get these parameters or does it create them itself?
I can't display these the parameters in ma table as below
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st May 2024
Jaroslaw Burtny [DevOps Member]756 Posted 18th January 2024 0 Comments
Hi
The problem with DCF connection in dashboards is probably because I cannot initiate connections in menu GENERAL PARAMETERS ( Framework Connectivity)  for Element AppearTV X10 and BridgeTech VB 2220 as below
But in Element TMux Ateme I see these connection as below :
I can see only one Element ID 62202/7 (AteneTMux) with these parametres in dashboard :
How can I takes these parameters correctly on DMA and next to dashboard for DCF connection.
Is it somewhere in the driver? something needs to be marked in driver or a bad driver on DMA?
Br.
Jarek
Jaroslaw Burtny [DevOps Member] Answered question 18th January 2024
