Why are the total alarms and unread alarms different between 2 alarms tabs when I activate filters?
Solved1.41K views29th July 2024Alarm Console unread alarms
Yvan Barbotin [DevOps Member]50 26th July 2024 0 Comments
Hi community,
When I activate filter to search for a specific severity or parameter description value, I don't have the same number of active alarms (in the footer) or same number of unread alarms as when I have no filter enabled.
You can see an example with active alarm tab with and without filter.
Thanks for your help.
Michaël Pincket [SLC] [DevOps Advocate] Answered question 29th July 2024
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 29th July 2024 0 Comments
Hi Yvan,
I see you have some correlation alarms in your alarmconsole. In case you use a quick filter, the base alarms of the correlated alarm are counted as well (even when the correlation tracking is enabled). In case the base alarm of the correlated alarm matches the filter you will see it as a separate alarm in your tab as well (even when the correlation tracking is enabled).
I hope this makes clear why the counters of both tabpages are different.
