Why are my HTTP Connection Settings hidden?
Solved2.64K views18th October 2023connection settings Connector
Thomas Remmery [SLC] [DevOps Advocate]1.06K 17th October 2023 0 Comments
I'm trying to edit the HTTP connection settings for an element, but for some reason, they are not visible in the edit view.
This is my connector header and portsettings.
Anyone who knows what the issue could be, or is this some kind of bug?
Thanks in advance,
Thomas Remmery [SLC] [DevOps Advocate] Selected answer as best 18th October 2023
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 17th October 2023 2 Comments
Hi Thomas,
I just tried it on my local element and there is works fine.
I correctly see the HTTP Connection settings.
So it has to be something environmental:
- bug in that specific DM version?
- where you trying to create a new element or to edit an existing one? in the second case, maybe that element is somehow corrupted?
Thomas Remmery [SLC] [DevOps Advocate] Posted new comment 18th October 2023
Jeroen Neyt [SLC] [DevOps Advocate] commented 17th October 2023
In the case of config corruption, it might be interesting to check the Element.xml and more specifically the ProtocolType tag of the interface. For an HTTP interface that value should be set to 10.
Thomas Remmery [SLC] [DevOps Advocate] commented 18th October 2023
Hi guys, thanks for the input. I noticed this issue on 10.3.10, the element I was editing was an older one. When checking the element.xml file, I could see that the protocol type was correctly set to 10. However, the busaddress was empty (see comment from Laurens Moutton). Creating a new element and specifying the BusAddress seems to have fixed the issue.
