which dll is contain Skyline.DataMiner.Automation which is required for Engine class
Solved1.30K views17th July 2023engine
Niraj Deval42 25th February 2022 0 Comments
I would like to attach dll to the project outside Dataminer which contains Engine class, I think Engine class is under Skyline.DataMiner.Automation. I would like to know which DLL contains Engine class.
Jeroen Neyt [SLC] [DevOps Advocate]2.53K Posted 25th February 2022 1 Comment
That would be SLManagedAutomation.dll that can be found in the Skyline DataMiner\Files folder.
Niraj Deval commented 25th February 2022
Thank you so much, Jeroen.
