Where to locate Sevice Definition ID GUID?
Solved2.78K views3rd August 2023SRM SRM Booking Manager srm service definition
Tyler Brown [DevOps Advocate]299 2nd August 2023 0 Comments
I am currently in the process of trying to create a silent booking in SRM. I have been following the code that was provided in the documentation, however, I cannot seem to locate the GUID required for the service definition ID. Does a new one need to be generated or is this referencing something else?
Thank you in advance.
Edith Lansens [SLC] [DevOps Member] Selected answer as best 3rd August 2023
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 3rd August 2023 0 Comments
Hi Tyler,
You can find the details on how to get the service definition id here.
