Where are view structure and element locations stored?
Solved1.79K views13th November 2023database migration views
Reza Biglari [DevOps Member]662 10th November 2023 0 Comments
Looking into a Dataminer agent files directory, I can see there’s a Views.xml file which appears to host this data. I am although unsure if this data is just what’s replicated locally from the database or that the view structure is never stored in the database in the first place.
This is mainly a question about migration strategy from one DMS to another, considering that both source and destination systems use a self-managed Cassandra cluster, and if Dataminer agents are to be rebuilt from scratch in the destination system. in addition to migrating the database, is there any other data which require carrying over from the DMA servers themselves to the destination system?
For the purposes of this question, we can assume an Elasticsearch/Opensearch setup is not used.
Reza Biglari [DevOps Member] Selected answer as best 13th November 2023
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 13th November 2023 0 Comments
Hi Reza,
The view structure is stored only in the views.xml file, this info is (currently) not stored in any of the databases.
