When will a WebSocket connection go into timeout
Solved2.25K views13th February 2023element_timeout heartbeat protocol timeout WebSocket
7
Andries Deklerck [SLC] [DevOps Member]492 13th February 2023 0 Comments
Related to this this question, I have a new question.
I have a heartbeat implemented of a 1 min interval which will keep the WebSocket port open. The timeout time is set to 30 seconds. We send a command and don’t get a response back in 30 seconds.
Will the element go into timeout after 30 seconds or only after a disconnection of the WebSocket?
Andries Deklerck [SLC] [DevOps Member] Selected answer as best 13th February 2023
Flávio Jacinto [SLC] [DevOps Advocate]898 Posted 13th February 2023 2 Comments
Hi Andries,
The element will go into timeout 30 seconds after the disconnection of the WebSocket.
Andries Deklerck [SLC] [DevOps Member] commented 13th February 2023
And if there is no disconnection from the WebSocket within 30 seconds?
Flávio Jacinto [SLC] [DevOps Advocate] commented 13th February 2023
DataMiner Elements will enter into timeout if there’s no succeeded communication between the Element and the product within the timeout time configured at Element Wizard level, which in this case is set for 30 seconds. Therefore, within the 30 seconds window no timeout will occur in this case.
