When to use Connection State vs Element Alarm State?
Solved1.53K views7th May 2024alarm template Connection State Element alarm state
6
Shawn Michaud [SLC] [DevOps Advocate]994 18th April 2024 0 Comments
I have an Alarm Template for a SNMP device configured as shown below.
  • Is Element Alarm State=Timeout the same as Connection State=Not Responding?
  • Is there benefit to using one over the other?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th May 2024
Robin Spruytte [SLC] [DevOps Advocate]798 Posted 19th April 2024 0 Comments
I couldn’t find much info about the Connection State parameter: I checked a couple of my elements and it seems to have ‘Undefined’ for all connections. However if the parameter is working fine for you, you could follow this logic:
Communication State comes from a table that show information for each connection individually so I would say it could be better to use if you have multiple connections.
Next to that, the element usually has a fixed time before it goes into Timeout. If this is not the case for the Connection State, that could be another reason to go with that parameter instead.
