When does alarm focus icon appear?
Solved2.70K views11th July 2023alarms
Bruno Sousa [DevOps Member]669 4th May 2022 0 Comments
Hello
When does the alarm focus icon in the alarm console appear?
Do we need to enable the "incident tracking" feature to have this?
Thank you.
Best regards
Bruno Sousa
Tobe Deprez [SLC] [DevOps Advocate]949 Posted 5th May 2022 2 Comments
In addition to the previous two answers, you also need to enable the focus column in the alarm console.
Whether the alarm has focus is then shown in this column.
The icon being present, means the alarm has focus (i.e. the alarm isn't recurring or frequent). The icon not being present means the alarm does not have focus (i.e. the alarm is recurring or frequent)
Bruno Sousa [DevOps Member] commented 5th May 2022
Do you know if Is it possible to send to other systems ( via SNMP Manager traps) only these alarms if wanted? Any varbind that we could filter on?
Thank you.
Best regards
Bruno Sousa
Tobe Deprez [SLC] [DevOps Advocate] commented 5th May 2022
I am afraid this is not possible, because internally these are two messages (i.e. the AlarmEventMessage vs. the AlarmFocusEvent) that you would have to combine. If this is important to you, I would suggest you propose this functionality on the feature suggestion page (https://community.dataminer.services/feature-suggestions).
