What should / can I do when experiencing problems with my failover system?
Solved2.16K views22nd February 2023Failover
9
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 22nd February 2023 0 Comments
I mainly want to know what I can do & provide Skyline to assist / help investigate problems, unexpected behaviors in a failover setup.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 22nd February 2023
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K Posted 22nd February 2023 0 Comments
I would check the failover status window from System Center --> Agents --> Failover and then continue the investigation. Usually, the log file SLFailover.txt (in C:\Skyline DataMiner folder) contains all the info related to failovers such as when a failover occurred etc. There is another file called FailoverStatus.txt in the same folder that shows the current state of the DMA in failover (whether it is going online/offline etc).
Arunkrishna Shreeder [SLC] [DevOps Enabler] Answered question 22nd February 2023
