What is the best way to receive resources from a specific pool during a specific timeslot in SRM
Solved1.93K views1st March 2023
6
Martijn Vanallemeersch [SLC] [DevOps Member]953 28th February 2023 0 Comments
What is the most efficient way in SRM to receive all available resources from a specific resource pool during a specific timeslot?
This is the code I currently use but not sure if this is the best/optimal way:
private List<Resource> GetAvailableResourcesFromPool(Engine engine, String ResourpoolName)
//SRM call to get available resources from a resourcepool in a certain timerange
var resourceManagerHelper = new ResourceManagerHelper();
resourceManagerHelper.RequestResponseEvent += (sender, e) => e.responseMessage = engine.SendSLNetSingleResponseMessage(e.requestMessage);
var resourcePool = resourceManagerHelper.GetResourcePools(new ResourcePool { Name = ResourpoolName }).FirstOrDefault();
var context = new EligibleResourceContext
ResourceFilter = ResourceExposers.PoolGUIDs.Contains(resourcePool.ID),
TimeRange = new Skyline.DataMiner.Net.Time.TimeRangeUtc(startTime, endTime),
return resourceManagerHelper.GetEligibleResources(context).EligibleResources;
Martijn Vanallemeersch [SLC] [DevOps Member] Selected answer as best 1st March 2023
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 28th February 2023 0 Comments
Hi Martijn,
Your code is fine, though if you use that method multiple times in the same script it may be worth to cache the resource pools to avoid calls for pools that you already queried before.
Also be aware that  resourceManagerHelper.GetResourcePools can return null so better check on that.
