Web Services (v1) using HTTP POST instead of SOAP
Solved1.88K views19th November 2021API v1 DataMiner API v1 API
Philip Argent [DevOps Advocate]1.07K 17th November 2021 0 Comments
We’re integrating DataMiner with a third party system that will be pulling information from DataMiner using API V1, the third party prefers using http post instead of soap.
As per the help page help.dataminer.services the note at the bottom states a section needs uncommenting to get this working outside the local host, which I have done in my testing.
Is there any reason why this is disabled by default? and should I be pushing the third party to use soap instead of http post?
Gellynck Jens [SLC] Answered question 17th November 2021
Gellynck Jens [SLC]2.71K Posted 17th November 2021 7 Comments
Hi Philip,
Thanks for pointing this out, this could be an outdated section in our documentation. I tried this on a remote server without uncommenting that section, and my SOAP requests (using the POST verb) still succeed.
Most DataMiner web applications are using the JSON API in the background, so I would recommend using the JSON API instead. See this page for more information.
Wim Bruynooghe [SLC] [DevOps Advocate] Posted new comment 18th November 2021
Philip Argent commented 17th November 2021
Thanks Jens,
With it commented on my server I get a 500 error, so needed to uncomment it.
I’ll update the calls we’re making to use json instead of soap.
There’s no issue using http post over the soap wrapper in the json.asmx request then?
Gellynck Jens [SLC] commented 17th November 2021
This is likely disabled by default for security reasons. I don’t think there should be issues using HTTP post using the JSON.asmx requests.
Thank Jens, I’ll update the details to be used.
Wim Bruynooghe [SLC] [DevOps Advocate] commented 17th November 2021
It is indeed disabled by default for security reasons. When enabling it, anyone can browse to http://dataminer/API/v1/json.asmx and easily run the web methods using the test form. So it’s a setting for development purposes, it is not needed to enable this when using SOAP or JSON. The HTTP POST method is provided as-is, it won’t work for all web methods. So either use SOAP or JSON.
Philip Argent commented 18th November 2021
Thanks Wim,
I’ll steer them away from http post then.
Is json.asmx still the better option to use over soap.asmx? from what I’ve looked at with the calls and responses they look identical for both.
Show 2 more comments
