VS 2022 – Skyline.DataMiner.Sdk not found
Solved719 views5th November 2025
Stefan Schedletzky [DevOps Advocate]2.48K 3rd July 2025 0 Comments
when I try to open a new automation script project or user-defined API project I get the message "Skyline.DataMiner.Sdk not found". I have reinstalled the DIS without success, still the same issue. I had this issue already at the Empower event.
How can I fix it?
Stefan Schedletzky [DevOps Advocate]2.48K Posted 7th July 2025 1 Comment
Hi Michiel,
okay I will contact my squad for Nimbra NuGet.
For the publish button, I can't find it:
Stefan Schedletzky [DevOps Advocate] commented 8th July 2025
I found the dll and the publish button 🙂
