visual studio – dataminer templates are not showing up
Solved2.22K views10th July 2024Templates
komala allanki dheena bandu52 8th July 2024 0 Comments
Hi Team,
When I select File > New > Project in visual studio (2022 community version), template for dataminer is not showing up. DIS installation is also success and can successfully connect to DMA as well but when I try to create a new project , I don't see any template for dataminer (eg. DataMiner Automation Script Solution). Please help me on this.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th July 2024
komala allanki dheena bandu52 Posted 9th July 2024 0 Comments
Issue resolved. Even if DIS is installed successfully NuGet package download is not happened correctly because of network issue.
