Visual Overview – Link element by Element Name given by another element
Solved1.58K views12th September 2022Visio Visual Overview
Felix Wesemeier [DevOps Catalyst]2.54K 12th September 2022 0 Comments
I have an element containing a column with values matching to some other elements name.
Is it possible to link the element dynamicly with the value of a cell?
Example syntax:
Source:
Destination would be some parameter from an element with the same name as the source-cell.
Regards,
Felix
Toon Casteele [SLC] [DevOps Enabler] Answered question 12th September 2022
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 12th September 2022 1 Comment
Your example syntax was extremely close. Basically all you have to do is leave the element shape data and replace the last ‘:’ with a ‘,’.
Element – [param:sourceElementName,sourceParameterId,sourceIndexValue]
The param will be retrieved and the entire placeholder will be replaced by the resulting value, in turn leading you to a valid element shape data linking to the element you want.
param placeholder in user guide
Felix Wesemeier commented 12th September 2022
Thanks Toon, this is working 🙂
