Visio – Why is my SVG icon not shown correctly
Solved3.39K views29th September 2020Visio Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 29th September 2020 0 Comments
I have a visual with a Wireshark SVG icon on it but this isn't shown correctly. Why is that?
Cube:
Visio:
Olivier Decru [SLC] Answered question 29th September 2020
Olivier Decru [SLC]10 Posted 29th September 2020 0 Comments
I had the same issue in the past with a custom shape on our IT DMA. As far I know you can't fill up regular images with an alarm color, so I kept the SVG format and just worked around the issue by just adding extra nodes on the curve
