Visio: Show shape using param and property
Solved284 views23rd October 2026shape data Visio Visio Shape Data
6
Ben Russell [DevOps Member]102 23rd October 2026 1 Comment
I'm attempting to show a shape, when a specific param exists in column 8926, but it needs to also be for a specific service (identified by property:Cloud Core Service):
[sep:-$]<A>$A|Value|[param:MWCore Cloud Gold - DE & UK services,8926]|Regex=(?i).*-soundmouse.*
The above shows the shape on every service, irrespective of whether it's for this specific service.
As a test, a text block returns every row where the regex matches, from column 8926 (confirming it's not service specific)
However, I need the shape to show only where the param matches, AND the row matches the 'Cloud Core Service' property.
I've attempted to use SubscriptionFilter: value=8902 == [property:Cloud Core service] - tried both on Group and Child shape data, but to no avail.
Ben Russell [DevOps Member] Selected answer as best 23rd October 2026
Ben Russell [DevOps Member] commented 23rd October 2026
RESOLVED:
Using this logic: [param:Element,ColumnID,RowKey]
SHOW: [sep:-$]$A|Value|[param:MWCore Cloud Gold – DE & UK services,8903,[property:Cloud Core service]-soundmouse]|Regex=(?i:.*soundmouse.*)
José Silva [SLC] [DevOps Enabler]2.19K Posted 23rd October 2026 0 Comments
Hi Ben,
It looks like the issue may already be resolved in the comments you posted.
If this is indeed the case, could you select this answer to indicate that the question can be closed and no further follow-up is needed?
Kind regards,
