Visio Regex – syntax for parameter values
Solved1.38K views14th November 2024
Carys Blackburn [DevOps Advocate]723 28th October 2024 0 Comments
I have configured the following regex in my visio as the Shape Text. Adding [Name] however pulls back the name of the element. How do I write this to instead populate the value of a parameter? Thanks 🙂
Carys Blackburn [DevOps Advocate] Selected answer as best 14th November 2024
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 28th October 2024 5 Comments
Hi Carys,
If I understand your question well, you would like to have the parameter value as the input of your ReGex instead of the element name.
In this case, you can simply use an asterix ‘*’. If your shape wouldn’t be linked to a parameter, you could also make use of the Param placeholder, but this is not necessary here.
Kind Regards,
Jarno
Carys Blackburn [DevOps Advocate] commented 28th October 2024
Hi Jarno,
Thank you for your response. When I put and asterix in the Shape Text, the regex does not apply to the parameter name.
This regex expression removes the first two characters from a string, this technically works when I use [Name] and removes the first two characters of the element name but when I apply and asterix I get the whole param value back.
Many thanks,
Carys
Jarno Lernou [SLC] [DevOps Enabler] commented 28th October 2024
What value do you see when you simply put the asterisk in there without anything else?
Any chance that the separators of the RegexReplace are messing up the different arguments? In case a comma would be part of your parameter value, you could replace the separator: [RegexReplace:[Sep:,#]x#y#z]
When I just have the asterisk and nothing else, I get the same result as having the regex and asterisk (e.g. with: 2 001 without: 2 001)
Jarno Lernou [SLC] [DevOps Enabler] commented 6th November 2024
Hi, Carys. I’ve sent you an e-mail but haven’t received a reply. If the issue is still present feel free to provide more details.
Carys Blackburn [DevOps Advocate] commented 14th November 2024
Hi Jarno,
Sorry for the delayed response! I ended up being able to resolve this by using the Param Placeholder you referenced above – Thank you for that. I wasn't able to make it work with the * though.
Thanks,
Carys
