[Visio] Mapping an XPos and YPos from paramater
Solved2.21K views4th January 2023MAP Visio
Sergio Abreu [SLC] [DevOps Member]221 3rd January 2023 0 Comments
Building a visio to view some dve element in a map.
Since the lat and long are available parameters on the DVE, tried to use them on a shape like below:
But this does not work.
Using the custom properties as below
Works fine, but this element is an DVE and it does not include the xpos ypos properties, and the aim is to make it dynamically.
Any help is appreciated.
Sergio Abreu [SLC] [DevOps Member] Selected answer as best 4th January 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 3rd January 2023 0 Comments
Hi Sergio,
A possible option here is to enhance the table that is used to create the DVEs and add extra columns for xpos and ypos. Then you could use the following feature: Shape positioning based on coordinates stored in dynamic tables
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 3rd January 2023
