Visio Load specific cube side
Solved719 views30th July 2026Cube side
Gerwin van der Kamp [DevOps Advocate]4.09K 29th July 2026 0 Comments
Is it possible to switch cube to an specific side from visio or automation script?
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 30th July 2026
Paulo Henriques [SLC] [DevOps Advocate]2.05K Posted 29th July 2026 2 Comments
Hi Gerwin,
Currently, it is not possible to programmatically switch the active Cube side (workspace) from a Visio shape or an Automation script.
Cube side switching is handled entirely client-side: it is triggered only through direct user interaction in the Cube UI (clicking the workspace tabs, using keyboard shortcuts, or the Quick Menu). There is no server-side API, no Visio shape action, and no Automation script method that can trigger this action on a running Cube session.
What you can do instead:
- From a Visio shape, you can use a hyperlink or script action to open a specific card (element, service, view) on the current side, but not switch the side itself.
- From an Automation script, you can use engine.GetUserConnection() / IAS interactive methods to influence what the user sees, but again, not switch their active Cube side.
If this is a feature you need, we'd recommend submitting it as a feature request on Dojo, as it would require a dedicated client-side implementation.
Paulo Henriques [SLC] [DevOps Advocate] Posted new comment 30th July 2026
Gerwin van der Kamp [DevOps Advocate] commented 30th July 2026
Allright, is there a way to start cube with sides preloaded? I saw you can start it and open an specific element or view.
Paulo Henriques [SLC] [DevOps Advocate] commented 30th July 2026
We can connect to Cube using startup arguments, for example to open a specific saved workspace. However, as far as I am aware, there is currently no supported argument that allows Cube to open directly on a specific side.
You can find the list of currently supported arguments in the following documentation:
https://docs.dataminer.services/dataminer/Getting_started/The_DataMiner_User_Interface/DataMiner_Cube/Opening_DataMiner_Cube/Options_for_opening_DataMiner_Cube.html
https://docs.dataminer.services/dataminer/Getting_started/The_DataMiner_User_Interface/DataMiner_Cube/Opening_DataMiner_Cube/Cube_start_window.html#connecting-to-a-dms-using-arguments
