Visio – Linking shapes that are spawned per-row to an element
Solved514 views22nd January 2026Visio
Bing Herng Chong [SLC] [DevOps Advocate]1.55K 17th December 2025 0 Comments
Hi, Community Users!
I need some help with working through a use-case and would like to check if it is possible to use Visio to implement it.
  • There will be a table in a driver. The rows of the table will be dynamically removed and added.
  • Each row will relate to an element.
  • Using Visio, I would like to create a shape per row. [I am able to achieve. See attached Visio]
  • For each shape (per-row), I would like to print the name of the element on that shape and allow user to navigate to the corresponding element when that shape is clicked. Even better if it is possible to navigate to a particular page on that element. [this I need help with]
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 22nd January 2026
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 17th December 2025 1 Comment
Hi Bing,
This is explained in the "Combining data with linked elements" part of the Visual Overview training on dojo. Please check this video: Combining data with linked elements - DataMiner Dojo
Bing Herng Chong [SLC] [DevOps Advocate] Posted new comment 22nd January 2026
Bing Herng Chong [SLC] [DevOps Advocate] commented 22nd January 2026
Thanks for directing my attention to that video. I'll try to adapt the strategies mentioned in the video into the use case I'm trying to realize.
