Variable into an automation script
Solved1.52K views2nd October 2023#automationscript variable
Ryan Hepworth [DevOps Advocate]1.53K 2nd October 2023 0 Comments
Hi All,
Might be a silly question, I am trying to write to a variable in a text box using shape data SetVar.
Is the right syntax in the automation script:
service.GetGeneratedwithoptions to pull that variable into the automation script?
Thanks
Ryan
Ryan Hepworth [DevOps Advocate] Selected answer as best 2nd October 2023
Ive Herreman [SLC] [DevOps Enabler]14.46K Posted 2nd October 2023 0 Comments
Hi Ryan,
To pass on a session variable from your visio drawing to your automation script, you will need to add a script parameter to your automation script and pass the value when you trigger that script from your visio.
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_an_Automation_script.html
