Using the QA Simulator – trap sender feature
Solved576 views5th November 2025simulator
Bing Herng Chong [SLC] [DevOps Advocate]1.55K 1st July 2025 0 Comments
Hi, some help is needed to understand how to use the QA Simulator trap sender to parse and send time-date OCTETSTRING values as is. The following is the use case and issue observed:
(1) The trap is exported as PDML. It contains the following timedate value expressed as OCTETSTRING
(2) In PDML this looks as follows:
(3) In the tool's UI, the text is non-readable:
(4) And in the resulting trap sent, it is seen on wireshark to have changed values:
Q: Is this an issue or are we using the tool incorrectly?
A workaround is to manually update the original in the UI:
But the resulting value sent in the trap now introduces double-quotes:
Q: Is there a better workaround that results in the trap being sent to be exactly the same as the original trap?
frans siew [SLC] [DevOps Advocate]1.06K Posted 2nd July 2025 1 Comment
Hi Bing,
Personally I have not used the QA Simulator trap sender but haveyou tried using the Generic Trap Simulator, you can export and upload the csv from a trap receiver and that should give you the same result as the trap being sent
Generic Trap Receiver
https://catalog.dataminer.services/details/83fb1a4c-063c-4fa0-ad0a-d23e1f1510c3
https://catalog.dataminer.services/details/93297b7c-dbac-472d-9337-1d9099f97d02
Bing Herng Chong [SLC] [DevOps Advocate] commented 2nd July 2025
Thank you Frans for the alternative.
