Using serviceDefinitionFilter in Visio with Primary Key
Solved835 views4th December 2025defintion primary key service serviceDefinitionFilter Visio
Nick Chirumbolo [DevOps Advocate]1.01K 9th September 2025 0 Comments
I'm having an issue where the [serviceDefinitionFilter] placeholder does not seem to work when using a primary key in a Service Template.
I've tried on the same element/service/Visio and when I'm using a primary key in a table filter (With the ^pk^ notation before it), the [serviceDefinitionFilter] placeholder on a shape does not show any data, even though I can see the table row under the DATA section of the generated service.
When modifying the template to use a Display Key for the same table filter, the placeholder then will show the expected data.
Is this a bug? Or is serviceDefinitionFilter just not compatible with primary keys?
UPDATE:
Including a test service I've created below as requested. This should be enough info to reproduce on your end.
SERVICE TEMPLATE:
SERVICE:
VISIO
DCM Production version = 1.0.3.116
DMA Versions
Server version : 10.4.0.0-15486
Client version : 10.5.2505.3334-0352cbd4
Launcher version : 10.5.2521.1454-44921101
Nick Chirumbolo [DevOps Advocate] Selected answer as best 4th December 2025
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 19th September 2025 2 Comments
Hi Nick,
The serviceDefinitionFilter should be compatible with the primary keys. Could you share your shape configuration so we can further investigate why you don't see any data with the primary keys?
Michaël Pincket [SLC] [DevOps Advocate] Posted new comment 23rd September 2025
Nick Chirumbolo [DevOps Advocate] commented 19th September 2025
I've removed Primary Keys from the original service, but was able to reproduce this with a very basic service. I added screenshots to reproduce to the original question.
Michaël Pincket [SLC] [DevOps Advocate] commented 23rd September 2025
I have create a task to further investigate this issue. We will keep you posted!
