Using same automation script in interactive and non-interactive mode
Solved2.57K views5th May 2023Automation IAS
6
Gilles Vanhee [SLC] [DevOps Member]462 5th May 2023 0 Comments
I have a use case where I want to reuse a certain script which is already in interactive mode. But I was wondering if I can reuse this script to run it in the background as well without changing any interactive logic?
Thanks in advance!
Gilles Vanhee [SLC] [DevOps Member] Selected answer as best 5th May 2023
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 5th May 2023 0 Comments
Hi Gilles,
Yes that is possible, you just need to skip the methods that interact with the user.
