Using parameter data in LCA header
Solved1.34K views5th July 2024low code app
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K 1st July 2024 0 Comments
Is it possible to use data, in my case custom property of an element, from "All available data" to display in the header of a low-code app?
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 5th July 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 4th July 2024 1 Comment
Hi Benjamin,
Currently, this is not possible yet, but it is a great feature suggestion! Feel free to submit it here: https://community.dataminer.services/feature-suggestions/
There are other options to show that information in your page by, for example, using a state component. The information won't be added in the header, but at least you can put that state component at the top of your page.
Hope this helps!
Best regards, Ward
Benjamin Hodžić [SLC] [DevOps Advocate] Posted new comment 5th July 2024
Benjamin Hodžić [SLC] [DevOps Advocate] commented 5th July 2024
Thanks. I’ll make sure to create a feature suggestion
