Using DataMiner.Services for remote logon [Occasionally receiving Error 500]
Solved1.85K views22nd February 2023dataminer.services error500
9
Ian Harvey [SLC] [DevOps Member]844 14th February 2023 0 Comments
When using DataMiner.Services to connect remotely to monitor my DMS I am occasionally receiving an Error: Status 500
When searching the docs, I can see troubleshooting for Dashboards legacy app
https://docs.dataminer.services/user-guide/Troubleshooting/Error_Messages/HTTP_error_500.html
The above logs show connectivity is intermittent.
What other logs files can be used to diagnose the error?
Ian Harvey [SLC] [DevOps Member] Selected answer as best 22nd February 2023
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 14th February 2023 1 Comment
Hi Ian
can you take a look at the log files in "C:\ProgramData\Skyline Communications\DataMiner CloudGateway\Logs". This could tell us if the connection is stable.
Ian Harvey [SLC] [DevOps Member] commented 14th February 2023
Yes. Thank you, will update the comments of this thread with the result.
