Using an element variable as dummy in my script in my LCA
Solved638 views21st August 2025LCA variable
Dieter Pappens [SLC] [DevOps Member]618 20th August 2025 0 Comments
Hi, I have an app that has a dynamic page based on variables. One part of this page is a button that launches an automation script to start the fetch QAction from a specific element. This script has an element dummy as parameter.
From what I can see, I only have the option to select an element from a dropdown when configuring my script in the button component.
Is is possible to somehow link this to my element variable?
Dieter Pappens [SLC] [DevOps Member] Selected answer as best 21st August 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.53K Posted 20th August 2025 0 Comments
Hi Dieter,
It is not yet possible to link the dummies of an automation script to other data inside a LCA. If this is a feature you are interested in, you can create a feature suggestion. Note that this might not be as straightforward as it seems since these dummies have different 'conditions' such as protocol and protocol version that must be respected when linking.
As Gerwin mentions, a workaround could be to create an 'element Id' input instead of using a dummy.
Wout Mahieu [SLC] [DevOps Catalyst] Edited answer 20th August 2025
